Hi,
I'm looking for help regarding my ttid.
Yesterday i repaired my egr bypass valve, the cables hade been worn of.. The valve works fine again.
But after a short drive the SID sends a message that i need to check my coolant level.
And then i see that coolant has been spraying out on the wall behind the engine.. More like a water dim.. Can't locate were the leaking starts.
Is this just a coincidence, or did the working bypass valve make this?
Attached som photos, the first one is to show where the water spray ended up.. The other one is from underneath the egr valve
Sorry for my bad English
Skickat från min ONEPLUS A5000 via Tapatalk
