· Registered
I am wondering if any of you guys have ever had to change any of your park assist sensors and did you D.I.Y it, if so could you tell me how you went about it.
I am getting the park assistance contact service message appear on the SID every time i select reverse gear. I have tried cleaning the sensor's with warm soapy water but that hasn't worked so i am guessing that one ( or maybe more ) of the sensor's is faulty.
The park assist sensors ( 4 of them ) are fitted into the centre part of the black plastic strip on the rear bumper. I am wondering if i can remove the faulty sensor by just removing the black plastic strip from the rear bumper to gain access to the sensors or do i have to remove the rear bumper of the car to gain access.
Any help with this will be much appreciated. :confused:
· Registered
Not sure to be honest but they come as part of the plastic strip - I don't think you can buy the sensors separately.
I think I'd take the strip off and see if the sensors are removeable, but I suspect they'll be bonded in, in which case it's a complete trim piece with the sensors attached :eek:
· Registered
They clip to the bumper, not the strip.
You will have to remove the bumper to remove the sensors, it sounds difficult but it isn't too bad.
I retrofitted the OEM SPA kit myself in a couple of hours.
Just get an old sheet or something to lower the bumper onto once you remove it.
The strip is exactly that, a plastic strip with some holes in. Nothing to do with the sensors anchorage points.
