1 - 11 of 11 Posts
Good day, I have a 2004 Saab with Kenwood sat nav, but the display stopped working.
Do you know if when I buy an old Saab radio without navigation, the CD changer in the trunk will work for me? And will the volume buttons on the steering wheel work?
Thank you.
The Nav equipped car has a unique cable loom, interconnecting the head unit, changer, amp., another unit under the dash (can't recall what it does) and the 2 units under the parcel shelf. This pic shows most of it.
Even if, after you take out the nav head unit, the connector fits the standard audio head unit, which I doubt, you'd have to re-program with Tech 2 to tell the car what its got and what it hasn't.
I extracted this lot, but haven't installed it. I sold it to a guy intending to fit the whole kit into an og 9-3. He and his brother were experienced electronics buffs, so reckoned they could manufacture the section of loom behind the instrument cluster that I couldn't separate from the main loom, which was as thick as a baby's arm!
Easier to get a replacement identical Kenwood nav unit and marry it to the car?
Thank you so much for your reply.
It would certainly be easier, but also more expensive. Kenwood sat nav is not for sale in my country.
I only use the radio and CD player. I don't need navigation itself.
You have to change whole wiring loom (inc antennas) if you are changing Kenwood to regular Saab radio.
And do you know if it is possible to connect another radio, such as a more modern Kenwood, to these cables and antenna?
I enquired at the time, when I couldn't get the loom separated behind the instrument cluster. Just the section of loom that plugs into the head unit was more than £400.00. They are specific to the installation. I wonder whether the guy that bought the kit ever got it working in the 9-3.....
Discussion Starter #9
I got a used navigation from the junkyard.
But where the touchscreen didn't work ...
And it turned out that there was a problem with the motherboard in the original navigation.
My very skillful dad combined the "new" body with the old display and everything works as it should.
I walk around it on tiptoe.. :D
The Saab radio head is a balanced output design. Almost all aftermarket heads are unbalanced using RCA jacks. You have to install and adapter to use the Saab balanced input amps.
1 - 11 of 11 Posts
