So there seems to be a few problems with the car like dashboard lights won't work like the handbrake and others located in this bubble area.
The Back right hand side door won't open it did for about 4 times and then stopped.
The Driver window is half alive but this could be a motor and regulator, also have to hold the window button for the to roll up as opposed to pressing the button down or up.
Unsure if these are all connected in a way and if it's a electric problem or series of different ones and if people have had similar issues.
Nothing seems to be mechanically wrong just these electrics seem to be a issue .
Previous car had similar problems but loved it all the same.
Do you have any illumination at dash or in instrument panel?
Check door lock actuator and switch panel.
Re-learn finger protect of driver door window. Owner's manual will tell how-to.
the dash lights up upon the car starting nut the handbrake light doesn't come on when the handbrake is up.
when you say check the re learn what do you mean? as in apply new fuse.
think that's the problem for the door but hoped it could be something else.
Check handbrake switch under handbrake lever.
Owner's manual will tell how to learn finger protect.
