21 - 34 of 34 Posts
I laughed :).
When he said he didn't have a lock, but just a badge, I had a feeling someone was going say the lock was under the badge.
We aren't that mean here on Saab Central though are we? :p
My wiring was broken also, one wire snapped off and the rest the insulation was split.
As for the trunk lock, there is no external trunk lock on my car and indeed it is just a badge. When the first poster that commented that his lock was seized I went to look and there is none. So you may think Im a goof, but I have known my way around cars for many years.
Aside from replacement ($100 part), this is the next best thing to do, and it's not all that difficult. I actually kind of enjoyed doing it.
Trunk Wire-Harness Repair
2004 Saab 9-5 Sedan
One of the Saab 9-5 sedan's few design-flaws is that the wire bundle that runs from the car body to the trunk lid makes a 180 degree turn around the sharp edge of the plastic elbow in the lid. This eventually leads to broken wires and some fun electrical situations. These wires power the reverse lights, fog lights, latch actuator, anti-theft micro-switch, and license plate lights. You might notice for example if the micro-switch wire breaks the trunk can be wide open and the dash won't tell you, or you can open the trunk without the alarm going off, and the light in the trunk won't illuminate. My actuator wire broke so I had to crawl in through the back seat to pull the emergency release cord.
First off, you need to remove the lining on the trunk lid. There are a bunch of those push-pin fasteners along the edges, and you need to unscrew the torx screws that hold the grab-handle in place. If you have an earlier 9-5 with the warning triangle mounted in the lid, I couldn't figure out how to remove the brackets without breaking them when I did this repair in my 2001. In my newer car, a 2004, the triangle was deleted, but I still had to destroy the two black fasteners to get them out. If anyone knows secret I don't I'd love to hear it! If your 9-5 has the emergency pull release, the cable slips out of the clip so you can pull the handle off.
Circled below in red are all the harness connectors. From left: reverse/fog housing, micro-switch to tell anti-theft the trunk is open (top), license plate lights (bottom), trunk actuator, and the other reverse/fog light housing. Circled in green is one of the white clips that hold the wires against the lid. Bend them to one side and wiggle a little and they come out pretty easily. I labeled all the connectors before unplugging them but probably could have managed without that step.
In the trunk now, open the door to access the brake lights on the driver side. The green bundle of wire in electrical tape going to that white connector is the trunk lid harness. Release the tab on the connector and unplug it.
If you stand to the side of the car and twist the plastic elbow that runs into the trunk lid clockwise and HARD, the right-side clip will release (sounds like it's breaking, but it shouldn't) and the left side then slides out. Where the harness runs into the body of the car is just a rubber hose and it pulls right out. The hard plastic tube clipped onto the hinge assembly next to the gas lift un-clips from the hinge.
Here's what it looks like out of the car:
I bought some 18 gauge automotive wire from Walmart and shrink tubing from Radio Shack. I spliced in about 12" of wire, but you might even want to do more so that your splice connections on either side can be in the car and in the lid and not running between. I crammed all mine into the hard plastic tube attached to the hinge so they wouldn't bend. For the splices I cut 1/2" of insulation off the ends, twisted the wires together, soldered them, and used a heat-gun (HOT - BE CAREFUL!) to shrink the shrink tube.
Now you just feed the harness back into place. I wrapped the section of wire that bends tightly in a couple layers of electrical tape to give the bundle some rigidity. Hopefully it will last!
nice out line. i just had to do mine last night. the wire for the trunk was the only one completely snapped but there were 3 others that were allmost broken all the way threw.
Brilliant post, now added to the FAQ's thanks raquettelaker2 :cool:
This can be done without having to pull the wiring harness out of the car. Makes it a tad easier to sort the wires, but I did mine (9 of 10 wires completely sheared off) with adding an extra 12 inches of cabling to boot, while harness was in the car.
I think I'll repair mine the right way sometime soon. I've had a wire connector on there for months, but I might as well do some preventative maintenance. :D
Here is what they look like out:
I used a flat blade screwdriver to gently work them out and both came out without being trashed.
On another note... I would suggest doing the soldering and shrink wrapping prior to covering the lot with electrical tape. Otherwise it can make for a really hard time fitting the lot through the plastic tube or the connector that goes to the trunk.
You should use a proper tool for taking them out. It looks like a narrow putty knife with a "V" cut out in it. The other fasteners with a round button in the middle, you just push the button in and they will come out easy.
I had to repair the trunk wiring again this weekend; could someone tell me the part number for the plastic nipple at the top of this pic below? According to the popular writeup you can "twist the plastic elbow that runs into the trunk lid clockwise and HARD, the right-side clip will release (sounds like it's breaking, but it shouldn't)";
Well it broke :evil:
I've looked on eeuroparts, saabpartspeople, and thesaabsite without any luck...
Try this place:
http://www.jimellissaabparts.com/default.aspx
They seem to have EVERYTHING.
I got lucky, mine came off with no problem when I repaired mine on Tuesday.
Great link J-rod. Cheers for this one. I think I found it. It might be number 11 in the page at this link: http://goo.gl/ql76o
Part number is 4927596, which comes up as DUCTCABLHARNWGN in the decription from the Genuinesaab parts lookup page. Can somebody with an EPC confirm that this is the right part and that it fits the sedan as well? I gotta get my hands on an EPC once and for all... ;oops:
The diagram you posted is taken directly from the EPC and as you can see it shows a sedan....so it looks like the right part.
21 - 34 of 34 Posts
