I can do standard stuff. Will put turbo as well as I have it and it might be useful to others!
Note: All lift figures are for 0 valve clearance. All durations are for nominal valve clearances.
B engine:
Carb (MY75):
Lift Inlet 10.4mm
Lift Exhaust: 10.6mm
Timing:
Inlet opens 12deg BTDC Closes 56deg ABDC
Exhuast opens 56deg BBDC Closes 12deg ATDC
Carb (MY76-)
Lift Inlet: 10.3mm
Lift Exhaust: 10.5mm
Inlet opens: 10deg BTDC Closes 54deg ABDC
Exhuast opens: 54deg BBDC Closes 10deg ATDC
Fuel injection:
Lift inlet: 10.8mm
Lift exhaust: 11.0mm
Exhaust opens: 46deg BBDC Closes 18deg ATDC
Turbo:
Lift inlet: 10.3mm
Lift exhaust: 10.5mm
Inlet opens: 12deg BTDC closes 40deg ABDC
Exhaust opens: 62deg BBDC closes 2deg ATDC
H engine:
Carb:
Lift inlet: 10.8mm
This is the same as the B engine injection cam.
Bit more info here on standard and aftermarket cams for the H engine in the 900:
http://www.pajjakid.com/ubipa/Camshafts.htm
