1 - 7 of 7 Posts
I brought my Saab 93 in because I had to have 2 FOBs programmed and the module behind the steering wheel replaced.
When I left the shop turning the wheel made noise.
The noise got worse and I brought the car back in.
The shop says the bearings are bad in the steering column.
They would have to replace the entire steering column.
They only give me a discount on parts and I don't want to spend $750 to get this issue fixed.
How big of a job is replacing the steering column?
I don't know where the bolts are located that attach it.
Can the bearings just be replaced instead of the whole column?
I can purchase steering column at a salvage yard for $45.
Should I feel safe the bearings in a used column will last long?
Or should I bite the bullet and purchase a new column for $250?
You sure it's the column? And why did it only surface after they worked on the car?
Have a friend sit in the car and turn the wheel back and forth and see if the springs are binding in the front suspension.
Yes they are Saab mechanics and they turned the wheel and showed me noise coming from the column
Yes they broke it
Sounds like they did a **** job.
And what is this "module behind the steering wheel replaced"? The CIM? Did they put in a new one?
Saab 93 steering column issue
Yes they did a sh^$%ty job
Yes they were replacing the CIM.
My question is can I get a hold of a repair manual for replacing the steering column?
Or for replacing the steering column bearings?
Was it new or used? clockspring could be busted.
1 - 7 of 7 Posts
