I think they all come with a nice trailer lighting harness. They (the ones I have seen anyway) are tucked behind the trunk liner over by the LH lighting assembly.
Here is some info:
All cars are electrically prepared for the fitting of a towbar. For this purpose, 8-pin connector 258 (H8-5) is installed in the luggage compartment on the left-hand side under the left-hand rear light.
Current is supplied via connector 258 (H8-5) to the following lights on the trailer:
Pin 1 Brake lights 30 (from brake lights switch 29).
Pin 2 Rear light 14, right-hand side, and number plate lighting 15 (from lights switch 10 and fuse 29).
Pin 3 Direction indicators 28, right-hand side (from flasher relay 23).
Pin 4 Direction indicators 27, left-hand side (from flasher relay 23).
Pin 5 and 8 Rear fog light 33 (from rear fog lights switch 161).
Pin 6 Rear light 14, left-hand side (from lights switch 10 and fuse 30).
The grounding cable from the towbar's electrical connector must be connected to rear grounding point G3 on the car, using a separate ring cable terminal.
