Hi all
I am going to pick up T5.5 parts for my project from some 9000 turbos at the wreckers...
I just want to reconfirm that all 94-94 T5.5 cars (look at ECU to determine if T5.5) have the same / compatible sensors, in addition to this is there any way I can test any of the sensors before I remove them so I know they will work? Can I use a multi meter or something?
Crank position sensor
intake air temp sensor
coolant temp sensor
APC valve
MAP sensor
DI cassette
Throttle position sensor
Auxiliary air control valve
I understand most I'll probably just have to guess if they're working, most are cheap so not too stressed about if they don't work....
Thanks!
Yes to your question.
If at all possible get all the sensors from one car, that runs right, save a ton of head scatching when it does not start...
Hey thanks for your reply,
I realised that I can probably use T5suite to detect which components are not running right as I think T5suite has a check engine light section doesn't it, or an error reporting log from the ECU?
