I just purchased a 1989 SAAB 900 Turbo 3 Door. There are some cut wires hanging down between and under the driver door and the front quarter panel. What do these wires go to? They were very obviously cut on purpose. If you need a photo to help I can get one Friday.
Discussion Starter · #2 ·
Also if this helps the sunroof does nothing, the automatic seatbelts have been replaced with normal seatbelts and the the fans inside the car don't blow.(no ac or heat)
The wires under the front quarter panel might go to the side indicator, if you have one. Test it with a multimeter and your turn signals.
I had the same thing, except the bulb was still attached. Started wondering why my door hinges were glowing at night with the turn signal on.
Now that I think about it the Side indicators dont work they worked when we first purchased the car but now they stay solid and dont flash. The wires are about the width of an index finger and and thumb together so rather thick.
