I have a 2007 Saab 9.7x and I need to replace the controll arms and mounting brackets. Will 2007 Chevy trailblazer controll arms and brackets work
Assuming upper front control arms, yes they look to be the same. If you run the Saab part number through GMpartsdirect.com it can often show you the other vehicles that part fits... ;)
please check parts closely. Some aftermarket upper control arms "neck out" on full rebound ( maximum droop travel) and damage the joint; the pin can pull out of the socket as it does so. Best to use genuine GM parts, Trailblazer parts cross over.
