Hello,
My car has been setting for 5 years. I live in Florida. It will not start now.Water in the gas? Other possible problems?
Since it is a V6, even a bad DIC won't stop it from trying to start, unless both DIC's are bad.
My DIC's usually had one of the 3 spark plugs fail, so I was running on 5 cyls. This is a different failure mode compared to the 4 cyl DIC's. I understand they fail on all 4 cylinders.
The V6 is pretty tough, minus the timing belt issue. CPS's require replacement every 75K or you are on borrowed time.
Anyway. Fuel pump running? CPS working?
