Hi.
I have a heat issue on my SAAB 9-5 MY1998.
When the car has reached its working temperature (needle in the middle), and I am parked, the vents are blowing cold air and fan speed builds up. Once I start driving (without changing anything) not fast ~45-50km/h, the fan starts to slow down and it starts to blow hot air.
Then again, without switching off the engine, when I am parked, the heat gets colder and fan starts to speed up.
I have changed thermostat this April, but if that would be faulty, it would be other way around - when parked, it would get warmer, and while driving - colder.
The coolant valve I changed last year October.
The coolant fluid is a little bit over the Max when hot.
I have run Climate control calibration with 0 errors.
I am not sure when this appeared, because I was not driving the car for 2 months and in summer I was not keeping an eye on heat.
What I changed today is the dump valve with aluminium one, because in May I bought an aftermarket one from Professional Parts Sweden and it was already broken after 2 months (drops RPM to/almost stall when let go of peddle).
This valve comes with 3 spring, with one pre-installed. I left the default spring in, because, when I applied suction with my mouth, I could feel a little movement on the valve opening.
But, as this dump valve is connected to vacuum controller by the firewall, which is also controlling vacuum for heater valve, could it affect the performance of heater valve?
So, has anyone had this symptoms before? Because google is not much of help here.
Are these the symptoms of air in heater radiator?
Should I replace the dump valve spring, because it is too hard?
Or, should I do a vacuum mod, eliminating dump valve from the vacuum controller by the firewall?
Thank you.
Thank you.
