1 - 11 of 11 Posts
Can you help me out please.
Not sure which engine or stock turbo (maybe td04hl-15t ????) is in this car, but at 8000' elevation the turbo stopped working. I've been up to 11k before OK. No noise, no smoke.
In the attached video I switched out some parts and checked the vacuum lines (new about a year ago) and all hoses and clamps for leaks or cracks but all appear in good shape.
I have not done a smoke test.
The waste gate is opening and the turbo spins by hand with maybe some slack.
See video.
You need to secure wastegate rod. If it pops up, you will have P1105 DTC.
I've got a couple of leftover extra BPC's. you can have one for the cost of shipping. PM me if you want one.
Also, check the wiring to the BPC, I found mine frayed that was causing a lack of boost. That part of the harness runs along the engine and can get damaged due to all of the heat cycles.
Happy Thanksgiving
Here's the boost gauge video
Does it tell you what's next?
TY
you won't often see huge boost in this car unless there is a load on the engine. (so take it for a ride and stomp on it while the car is in gear and moving)
The "boost" gauge on the T7 systems is really a reflection of engine load, and while the car is in neutral there is no real load (and the ECU knows that) so it doesn't boost since it doesn't have to.
Discussion Starter #11
Noted. When driving hard that's all it does, the engine has little power and no boost beyond these levels in this video.
1 - 11 of 11 Posts
