Hello, this is my first article here. The car can't start, but all the lights are all going and nowhere else is to blame just can't start the engine, the only way to start the car is to put the wire over the straight relay instead. A new relay has been put in but the car cannot be started either. maybe something like this has happened
Window Automotive tire Plant Automotive lighting Motor vehicle
Trunk Electrical wiring Bumper Audio equipment Automotive lighting
Automotive lighting Trunk Bag Luggage and bags Automotive exterior
Automotive tire Window Automotive lighting Hood Motor vehicle
Hi, have you been playing around with your front wheels, I was getting the same notice after I removed the front wheels as I had to remove my transmission, disconnecting the break sensors and power steering plus stabilising bar can send these messages.
You should check the connections and make sure all bolts and brackets are tight. If you still get the message you may have to replace the break sensors or the stabilising rubber and bar in the front end.
Lucky enough I had a spare car to get these parts and once replaced the messages disappeared.
Hope this helps.
Check carefully ECU wiring looms, usually there is cracked wire(s).
Check ECU carefully for corrosion.
