I am currently experiencing some problems with my 2001 9-3 (base 5spd) 140,000 miles. It is randomly stalling out and not restarting unless you unhook the battery cable to reset the computer. Then it starts just fine. The garage, a small independent saab shop, that it was taken to could not find anything wrong with it other than low/ no fuel pressure when it stalls. When they took it out for a test drive it it stalled and would not start. They unhooked the battery to reset the computer and it started fine, fuel pressure was fine. They think it may be the ecu? The cruise control does not keep speed when going up hills, I'm not sure if this has anything to do with the problem or not. It worked fine before this started happening but now it does not work correctly. No check engine light either. What are some other ideas other than a bad ECU? The car is also revving between gear shifts, it usually has a small blip but now its jumping 1000 rpms between shifts. Thank you for reading this and any ideas are much appreciated ;ol;
