Yes you should. Even with the key off you should see lights if your door is open due to the computer still being on.On star fuse is good,
One question - should I have a light coming out of the bus ( fibre optic lines ) under the seat with the key on?
the point of the bypass is sometimes when amp1 goes the optical loop is broken and the entire system wont turn on. sounds like your amps output is dead but the optical loop is intact. if you want door and center back you need to fix or replace the amp
Yes and Yes, but what about the doors? What is going to take bass duties?Hey, I know this is an old thread but I have a question...
My AMP 1 is draining my battery so I would like to know if I can
-Bypass the fibre optics in AMP 1 and remove the AMP while leaving the fibre optic connection
-Install a after market amp in my boot to power the rear shelf speakers and front dash speakers
that way I dont need to bother buying a ****ty 50w Saab amp and can buy a decent aftermarket amp to power my speakers without affecting my battery/chimes/stereo/ etc..
Thank you, any information is appreciated.
