1 - 11 of 11 Posts
· Registered
Hello first post here.
I have a saab 9-3 1.8t hirsch 2007, which has a power issue.
When driving randomly they car wont boost. in 1 gear it takes around 10 sec. to reach max rpm and at accelerates very slow.
The same applies to other gears aswell. If i run the car through a ignition cycle while driving or idle the car works fine.
The issue then persist 5-35 minutes afterwards.
I got some error codes P0101 and P0420
I have tried replacing the bpc valve (diden't do anything)
I replaced the MAF, that "worked" for about 2 hours, now it's back to the same issue.
I have no idea where to start.
Any answers would be helpful
· Super Moderator
P0101 can be caused by secondary/unmetered air entering the intake side check ALL pipie work on the intake inc IC pipes..P0420 is cat efficiency below threshold,could also be the rear oxygen sensor..
· Registered
Which one contributes to the lost power. And why does it work after an ignition cycle?
I new to these cars, do you have a diagram where I can see all the pipe work. The car gas been fitted with some do88 hoses.
1 - 11 of 11 Posts
