1 - 15 of 15 Posts
i remember seeing something about a rear wheel drive 9-3 or 900. does anyone have the link to it?
--Original Saab engine block and cylinder head. Engine tuned by Trollspeed of
Trollhattan, Sweden. Longitudinally mounted, four-cylinder, 16-valve with
twin overhead camshafts
--Garrett turbocharger with intercooler (3.0 bar or 42.8 psi at sea level) (anyone know what turbo? my guess is gt35...)
--Displacement: 2.0 liters
--Bore/stroke: 92/77 mm
--Compression ratio: 9.0:1
HP Rating: 750 HP at 8,000 rpm
Peak torque: 545 lb.-ft. at 6,500 rpm
Transmission: Four-wheel drive with programmable active differentials and
six-speed Prodrive gearbox
Weight: 2,090 lbs.
0 - 60 mph: 2.3 seconds
Top speed: 155 mph
http://www.youtube.com/watch?v=ieNvcv4mAnM
Weight: 2,090 lbs.
Top speed: 155 mph
Not bad I suppose!
Weight: 2,090 lbs.
Top speed: 155 mph
i've seen acouple different numbers for his hp, and torque, but the latest suggest more around 800 and 700 torque. I'm pretty sure the awd system is subbie sourced, but I've heard of dsm sourced ones being easier to install.
as for the turbo i thought he was running a t88, but once again theres alot of diff information I've seen on the car, and I'm sure he's gone through more than a couple setups
i was guessing with that gt35 up there, i didnt find that info just a guess
1 - 15 of 15 Posts
