If your control arm is bad just replace it, they are still around new. If your talking about the mounting location then well...I had that issue, not a bad fix for my mechanic.OS said:Does anyone have some pictures/description of the job to weld in a replacement partos of a controll arm frame? (links above are dead)
I *think* i still only have to replace the bottom part of the metal, is it possible to do that with the driveshaft in plae, if i protect it with rags ant sheet metal?
Cheers
OS
saabpics tends to come and go. try them again later!OS said:Does anyone have some pictures/description of the job to weld in a replacement partos of a controll arm frame? (links above are dead)
http://saabpics.com:3000/gallery2/v/Dougstuff/album115/86_severe_rust.jpg.htmlOS said:Does anyone have some pictures/description of the job to weld in a replacement partos of a controll arm frame? (links above are dead)
Cheers
OS
