So when I stop the car and allow it to idle (or park it) the car's RPMs drop down, and the car usually recovers, then this continues in a cyclic manner until either the car cannot recover or I hit the gas. The car shows no problems while driving. 6 months ago, I was sent an evap code (P0455) ad traced it back to some destroyed evap lines around the throttle body and a stuck open purge solenoid. I replaced the lines and put in a used purge solenoid, I have not gotten a code since. I pulled the IAC valve a few days ago, cleaned it out with carb cleaner, tested it, it worked fine, put some PB blaster through it, and put it back in the car. The idles seem to have smoothed out (no more highs and lows) however when parked after some time driving, the car still will stall out randomly, with no warning signs. Thoughts?
