Long story short:
1986 SPG 5 speed
The roll pin on the shift selector rod came out, fell into the differential and took a tooth out of the ring gear.
The pinion suffered no visible damage.
I have a donor trans from an 87 with a good diff, and a busted transfer case.
Already have it apart.
According to the tranny info page on fixmysaab.com, they are the same ratio.
What is the wise move here, if any:
1.Use only the ring gear from the donor trans?
2. Use the entire differential assy including inner drivers from the donor trans?
3. Something else?
Not being a tranny guy, per se, I want to keep this a simple as possible.
Help, tranny gurus!
1986 SPG 5 speed
3. Something else?
Help, tranny gurus!
