Ok, so I bought these rims for a set of snows.
Manufacturer/Model: VOXX Toscana
Bolt Pattern: 5-110
Offset / Backspacing: 40mm offset/ 5.57 back spacing
I thought I had done the research I needed and these seemed to fit based on the info above. While they do fit over the front calipers of my 2004 Aero (barely), they do rub just a bit on the inside edge of the 2 front wheels. I'm not quite sure how to describe it, but the front (outer) portion of the rim doesn't seem to have any trouble other than being VERY close to the rim. The rear (inner) portion of the rim is rubbing on the inner portion of the brake caliper assembly. It appears the caliper assembly gets slightly larger on the inside of the car.
Its rubbing at a point on the rim about 1/2" from where the rim profile starts to open up or expand. My question to you all is do you think I could get away with using a wheel spacer that would push the rim out the amount I need thereby giving the caliper enough room? I'm not familiar with wheel spacers and I'm a bit hesitant. I'm sure I'd need longer lug bolts as a result. Is this a bad idea?
Bolt Pattern: 5-110
