Hi I'm considering retro fitting air con into my 900. I'm aware that some of the wiring is already in place, but are there any major parts of the loom missing? For the second cooling fan etc...
Also is changing the bottom pulley (if needed?) for one which will run the air con compressor belt an engine out job? Any other major headaches to consider??
Cheers - JK
You can change the bottom pulley with the engine in. Way easier from the bottom, much easier with it out. But certainly very doable engine in.
Thanks JM! I just hope i don't end up with all the AC probs people have listed here of late!
