1 - 9 of 9 Posts
Hi there, I am a new here and I just got a 03 Saab 9-5 couple weeks and I hope if there is anyone can tell me where I can get the Rest of World done in Canada. Or is it possible to cross the border and get it done by the dealer?
Regards
Ryo
Welcome aboard.
When you get a chance, everyone would like to see some pics of your 9-5!
Pardon my ignorance....but what is "rest of world"?
Hello
Rest of world is a program which will change you headlight system, In Canada, by law, you have to turn on the headlight all the time. They call Daylight Running Lights (DRL), and my 9-5 will switch on Low beam all the time no matter day or night! but once you set Rest of World. you can have
Pos 0 > No Lights
Pos1 > Fogs and 5 Watt Headlamp / Parking Light
Pos3 > Low Beam, High Beam, Manual Control of Fogs.
so, you can use Pos1 to run day time and 3 to run night time.
http://www.saabcentral.com/forums/showthread.php?t=12126
regards
ryo
too much BC bud.
(rest of world?):eek: eh?
You just put in fuse #27 I think. BOOM DRLs. I have a US spec 9-5, you just put the fuse in and it passes Canadian standards without a hitch.
Welcome fellow Vancouverite!
thanks, but what kind of fuse did they put it in? can you tell me the color or the # which shows on the top of the fuse?
regards
Ryo
woywitka said:
too much BC bud.
regards
Ryo
The inside cover for the fuse box shows a diagram of all the fuses and what amp fuse goes in each slot.
G
It's fuse #35 and should be 15A (blue). There are 6 rows of fuses, #35 is on the second row from the bottom in between two green 30A fuses.
The Rest of World settings you are talking about only applies to the 9-3 (2003+). On those cars, it is not as simple as pulling a fuse to disable the DRL's.
ah,
No I understand 100%.
The car passes inspectin by putting in the DRL fuse no issues.
Discussion Starter #9
So, which means I can't use headlamp instead of Low beam during the day time driving!!!??
Ryo
1 - 9 of 9 Posts
