Replacement substitute for standard Bosch ignition coils in C900's
I'm looking at what can be used to replace a regular, bog-standard Bosch ignition coil used in Classic 900's with hall-effect ignition systems. Not the integrated ignition amp type. I don't think it matters between EZK and non-EZK setups.
If we take the standard Bosch coil spec that Saab seems to have used, with a primary resistance of around 0.5 to 1.0 ohms, and a secondary resistance of around 7.2 to 8.2 K ohms, what current-model Bosch coils that aftermarket auto parts sell can be used as a substitute?
For example, here in Oz auto parts shops sell Bosch-branded coils with names like SU12, GT40, etc. and there's an Ebay seller listing what are claimed to be 'genuine' Bosch coils with a 'BIC290' product code.
None of the listings give actual Bosch part numbers in the 'x xxx xxx xxx' format or give any actual technical specs. I don't know of any cross-reference between Saab part numbers and Bosch full part numbers or 'retail' product codes.
Would a Pertronix coil be a better choice? Say a # 45011 with 0.6 ohm primary...
Craig.
My '92 900 T16 came to me with a replacement coil. It's labelled Accel Super 8140. I have the breakerless Hall effect and this coil seems to work OK. I don't think it's rocket science.
I installed a MSD "can" type coil in my last vert. Not sure what problem you're trying to solve but the MSD had plenty of juice output...40000 volts
I'm currently trying to diagnose ignition issues with my 2.1 sedan and the coil primary resistance doesn't match the spec in the manual for the primary - I get 0.9 to 1.4 ohms when it should be 0.5 to 0.9.
I have a spare (generic bosch) I can try. Don't have a Pertronix on hand.
