Last week my car threw a P0785 transmission code which pointed to the SLS in the transmission. When I first started looking at this it looked like this was quite a bit of work to get the solenoid replaced, part of the transmission has to come off, drain, drain the cooler, etc. Fortunately for us (and not some Volvo and Maxima owners) the valve body cover can be removed and the solenoids replaced with the transmission in the car!
In the end, it's not too big of a job. This tutorial will show you how to do it with some photos. I took fewer photos once I got the thing opened up since my hands were covered with ATF and I didn't want to touch my phone.
What you will need:
First you need the new solenoid. These transmissions are primarily electrically controlled through a group of solenoids. The linear solenoids control things like the clutch and other fluid flow. There are also 5 solenoids that control the shifting for each gear. Rostra in North Carolina makes a kit that replaces all three of the linear solenoids and they also sell replacements for the individual gear solenoids. The Aisin AW55-50 is a pretty common transmission in Volvos, Nisssan's and Saabs (and others) I bought my kit from USA Industries on ebay for $209 which included all three linear solenoids (SLS, SLT, SLU) since I figured if I was going to go through the trouble I may as well replace them all at 145K.
You will need the following tools:
Note: it looks like you can either take the valve body cover off through the top by removing the intercooler hose or the bottom by removing the down pie and cat. I took the top route.
From above:
Start by jacking the car, take out the battery and the battery tray. (13mm for the battery, 10mm for the tray)
Remove the hose connecting the intercooler to the intake pipe. Two screw hose clamps hold this on.
Remove the retaining clip from the support under the battery for the TCM control wire that comes up next to the neutral safety switch and for the main ground. They are pushed through and a set of needle nose pliers from the back will release.
Remove the transmission dipstick and then the dipstick tube (if you have one, some transmissions don't) this is a 13mm bolt on top of the NSS.
From below:
Slightly lift the transmission with a jack, remove the torque rod. The transmission end is a 18mm bolt threaded into the transmission mount, the subframe end is an 18mm bolt with an 18mm nut on the other end that is difficult to get. Release the transmission
https://dl.dropbox.com/u/49074648/Aisin Transmission/Remove Torque Rod.JPG
There are three 16mm bolts that hold the transmission mount to the cover of the valve body. These are hard to get out since there is very little room to maneuver. There is no way to get a rachet in there, so you need an open end or box end wrench. Remove these three bolts, it's easier to get the top one out from above. . Since you unhooked the main ground cable from the frame above, pull the mount down and you can get a 14mm wrench onto the main ground, remove. Remove the transmission mount. You can snake your hand in around the subframe from the drivers wheel well side of the frame to get the other two.
https://dl.dropbox.com/u/49074648/Aisin Transmission/Torque Mount out.JPG
Remove both of the transmission cooler lines, drain the transmission. Mark one so that you know where it goes when you reassemble.
https://dl.dropbox.com/u/49074648/Aisin Transmission/Remove Cooler lines.JPG
I put baggies on the end of each one, taped them up and then pushed them through the subframe and out into the wheel well so they would be out of the way.
https://dl.dropbox.com/u/49074648/Aisin Transmission/Bag cooler lines.JPG
Remove all of the 12mm bolts that hold the valve body cover. There are several lengths of these bolts so keep them in order. A good collection of extensions and u-joints are useful in getting all of these out. The three on the top are best reached from above. The rest come out from below. I had one that I could not get the bolt out once it was loose since it hit the bracket on the subframe where the torque rod bolts. Make sure you put it back in the cover before inserting when reassembling.
Use a rubber mallot to tap the cover. If yours is like mine it's never been off so be patient. Once it pops off, let the remaining transmission fluid drain. Go to the top and fish the cover out.
Top View with cover off:
https://dl.dropbox.com/u/49074648/Aisin Transmission/Top View no cover.JPG
Bottom view with cover off:
https://dl.dropbox.com/u/49074648/Aisin Transmission/Botton View no cover.JPG
In this photo the solenoids that have a single wire (top of photo, bottom of valve body) are the shift solenoids for the individual gears. The linear solenoids are toward the bottom of the photo (top of f the valve body)
You now have access to the solenoids. The three linear solenoids are on the top starting with the SLU (black connector) on the top, the SLT (blue connector) and the SLS (green connector) on the bottom. To get the connectors out get a small screwdriver and insert it into the hole on the wire end of the "top" of the connector until the catch is released and then pull the connector out. Do this before you unbolt the solenoids since you want to be able to pull against the solenoids to get the connectors out.
From the top, starting with the SLU, unbolt the single bolt that holds in the retaining clip and remove the clip. Slide the solenoid out toward the drivers side of the car. put a little bit of ATF on the snout of the new solenoid, slide it in and re-install the clip. You will notice that the clip fits into a slot on the snout of the solenoid with a slot facing toward the clip as well so you can't really get it in wrong.
Now from the bottom, remove the bolt that holds the retaining clip that holds both the SLS and SLT. Again, remove the solenoids and replace with the new ones following the instructions. The Rostra solenoids orient the connectors differently so pay close attention to the instructions. The Rostra solenoids also require that you use their retaining clip to hold them in the proper position. bolt the clip back in and tighten.
Re-install the connectors, noting that you are putting the right colored connector in the right solenoid. It's nice that Aisin Warner color coded these for us!
Clean up the surfaces of the valve body and the valve body cover and apply sealant. I used some anaerobic sealant that I had left over from my oil pan job. Slide the cover in carefully from the top and bolt it down.
Then put all of the stuff back together in reverse of the above instructions. Fill the tranny with some fresh 3309. Mine gave up just under 4Q when I drained it.
Get out your OBD reader and clear the transmission and CEL and you're ready to take it for a ride!
There will be instructions with the solenoids on how to "retrain" the TCM to shift properly with the new solenoids. 5 "Garage" shifts P-R-N-D with 5-second pause, 5 10% throttle through the gears then stop, 5 30% throttle through the gears and then stop.
All in all it was about 2-3 hours of work to do this job. Unfortunately for me in the middle of it I found that the drop shipper for USA Industries sent me the wrong solenoids. Jack from USA was awesome in getting it set straight and fortunately their warehouse was in San Leandro, about 20 minutes from my house. I ran down there and swapped the parts. It took about an hour to put them in and button things back up. I could probably do the job in less than 2 hours now since I know what has to come out and wasn't experimenting with different wrench combinations to get things apart.
This is definitely a DIY job for someone who felt comfortable dropping the sump or swapped out a water pump or a turbo.
What you will need:
- 16mm combination wrench to take off the torque rod mount
- 18mm combination wrench and socket to take off the torque rod (both ends)
- 14mm combination wrench to take off the main ground from the transmission
- 12mm socket and a bunch of extensions/U-joints to take off the valve body cover
- 10mm socket to remove the battery tray
- 13mm socket to remove the battery and SLS/SLT bracket
- 8mm (? I think) socket to remove the SLU bracket
- screwdriver to take off the hose from the intercooler to the intake pipe
- a small screwdriver to take off the solenoid electrical connections
From above:
From below:
