Can it be done and work properly?
I'm having trouble finding stock on the replacement pump in Canada, so I thought I could borrow the pump unit (internal unit, not the whole fuel bucket) from my '90 900T. The pump from the turbo is Walbro 4500270.
Haven't been able to get the securing ring off to remove the 900S pump.
I noticed Bentley mentions the following pressures are different.
Yet NAPA and Rock Auto bring up the same pumps for the turbo and non-turbo. Ebay however does not. Who to believe?
from Bentley pg240-9/240-10
System pressure, fuel pump running, engine off:
turbo: 2.5 bar/36.3 psi
non turbo: 3.0 bar/43.5 psi
System pressure, fuel pump running, engine idling:
turbo: 1.9 bar/27.6 psi
non turbo: 2.4 bar/34.8 psi
I could see that if there are different pressures on the fuel rail, ~before~ the fuel pressure regulator, the regulator could take care if it, as long as the required pressure was higher (not counting back pressure).
If the pump had a lower pressure than required, it may not work.
Anybody tried it?
Anybody tried it?
