the battery had been running low in the previous weeks and wasnt charging correctly. a local auto electrician did a very basic check and said the alternator was not charging the battery ( this confirmed my battery measurements of +/- 12 volt before crank, which then drops to 11.1 when engine starts i/o going up to 13.5 or 14 v)
i ended up replacing the alternator myself, took me a week to do it ( * RHD* car, removed battery tray and fuse box, then removed gearbox brace to lower rear engine mount).
but no resolution of my problem, the battery is still not rising to 13.5 or 14 volt when the engine starts.
i thought that when i re-connected the wiring on the new alternator, that the thin wire attaching to it felt rather flimsy and loose where it was attached at the other end (somewhere higher up on the engine near the injector rail) , and might be frayed or damaged at this other attachment point . but i checked this thin wire going to the alternator as extensively as i could for any signs of cracks, corrosion or wear, but cant see any problems by simple visual inspection.
i traced it from its alternator attachment point all the way back to where it joins up with the yellow starter motor cable (and another sensor wire) and then enters part of the wiring harness (near the CPS sensor bracket, behind the fuel injection rail). at that entry point these 3 wires enter a hard plastic heat shielding cover , and i stripped this back 2 or 3 inches to make sure no damage was present , but cant visually see any problems
looking at the WIS wiring diagram to the alternator connections (wiring harness / charging system ), once this thin wire enters the harness it travels to the large electrical connector on the firewall just below the windscreen, not sure what i can check there
any suggestions on what else might be causing my alternator not charging the battery problem ?
- the battery is almost 2 yrs old and has been checked by the manufacturer's rep at the retailer i bought it from. i also had a loan battery from them for 2 weeks and still had the same problem
- error symptoms developed gradually over 2 months, slowly worsening (battery gradually weakening)
- "battery error light" and "exclamation point warning light" are on at dash
- OBD2 error code is PO560 = " system voltage"
i dont have access to a tech2, would this give a more specific indication of the error source/location ?
