1995 900S convertible
Discussion Starter · #2 ·
If you want to replace the cable and can’t find a Saab oem one, the dimensions are:
36” from post to starter with 5/16” terminal hole
12” from starter to alternator with 5/16” terminal hole
24” from post to fuse block with 1/4” terminal hole
Be aware that corrosion will hide "inside" ... rewrapping them is at best a temporary solution. There are chemicals that may clean the acid & corrosion out, but IME it's of limited effectiveness. When the cables are that far gone, you shoudl replace them.
