Is it possible to remove the sun roof easily? I was kinda thinking of taking my sunroof out and replacing it with one with a built in solar pannel for extra battery charging, I've been thinking about messing with Pizo's/solar pannels for a bit and this could be a good application.
It's pretty straightforward to remove the top panel. Open the sunroof, undo the 4 torx screws in the front edge, close the sunroof until it is open 2-3" and then lift out the top panel. Removing the whole frame is not complicated, but can be a bit awkward as it is quite heavy to lift out.
Sunroof
Ohh, that's easier than I thought, may have to take it off for a respray in the meantime!
Gotta find a pizo supplier now as a panel about the same size from Maplin is about £100. I'm sure i could build one cheaper, I think there quite simple, just pizo's n diodes.
