Very much a novice with this C900 S - 1986. Planning on replacing the water pump (Labor Day weekend). Removing the air compressor is the first task. I am thinking removing the compressor bracket is the best way to get to the water pump working area. I could remove the compressor 4 bolts, but they are not that accessible, even with the allen wrenches and a 17 mm wrench. The bolt on the bracket under the compressor is not that easy to get to with leverage. Looking for some suggestions or the proper tool suggestion to get the compressor off. My water pump is spitting antifreeze and this is a must do repair.
Thanks in advance for all who respond.
wcoze
wcoze
