What diameter are the wheels?
5*110 185/65R15What diameter are the wheels?
I dont think so, I bought from a Saab collector a couple of years ago. Maybe he put in Viggen front brakes at some point. Its a 2000 9-3 model, no turbo. This is the only picture I have of the front brake caliperDO you have Viggen front brakes?
According to wheelsize.com, the OE wheels are either 185/65R15 on 6Jx15 rims and an offset range from 39-41 or 195/50R15 on 6.5Jx15 with the same offset range. For the 2.3T the values are 215/45ZR17, 7Jx17 ET45 and 43 - 47.5*110 185/65R15
measure the diameter of your rotor , if its 308mm its viggen brakes on thereI dont think so, I bought from a Saab collector a couple of years ago. Maybe he put in Viggen front brakes at some point. Its a 2000 9-3 model, no turbo. This is the only picture I have of the front brake caliper View attachment 294177
Can you take a picture of the entire wheel from the front, or provide the part number of the rims? I am guessing they are either #3 or #7, but it's hard to tell.5*110 185/65R15
That is not the caliper, that's just the hub. You can take a picture of the entire wheel/brake assembly. And measure as best you can, the diameter of the brake rotor. It should be pretty easy to tell if it is about 288mm (regular) or 308mm (Viggen).I dont think so, I bought from a Saab collector a couple of years ago. Maybe he put in Viggen front brakes at some point. Its a 2000 9-3 model, no turbo. This is the only picture I have of the front brake caliper View attachment 294177
Well, that website is wrong. (No big surprise.) Offset of NG900 and OG9-3 (and OG 9-5) rims was 49mm, definitely for 15"-16" rims, and for 17" rims too I think, except for the specific Viggen five-spokes may be 41 mm, I don't know for sure.According to wheelsize.com, the OE wheels are either 185/65R15 on 6Jx15 rims and an offset range from 39-41 or 195/50R15 on 6.5Jx15 with the same offset range. For the 2.3T the values are 215/45ZR17, 7Jx17 ET45 and 43 - 47.
You can hold something against the rotor edge in a suitable spot, like a pencil even, sticking out towards you. Then measure as straight as you can from the middle of the axle to the pencil. Should be accurate enough to get the radius. Multiply by 2 to get diameter.It's hard to measure the rotor in place.
Not that it matters here, but just to clarify the information: the Viggen had a 42 mm offset on a 7.5 x 17" inch wheel. The double Y 17x7 was 45mm. The later 9-3 SS runs 41mm. All 16" wheels for our cars are 49mm as are the og 9-5. OG 9-5 seemed to also use 49mm for the 17's too although I've seen some variations- might have been factory-dealer swaps. I recall stacks of wheels in the showrooms - they had a lot of options back in the day.Can you take a picture of the entire wheel from the front, or provide the part number of the rims? I am guessing they are either #3 or #7, but it's hard to tell.
What size wheels were you using before? 15" or 16"?
By the way, there should be no problem with stick-on weights clearing the caliper! If they don't clear, the caliper is too close to the inner surface of the rim.
And in North America, where even base NG900 usually came with alloy rims, by 1996 or 1997 the only 15" rims used were 15x6.5. (I have owned a set of 15x6 Saab rims; they had winter tires and I replaced the compact spare with those for winter.) And the tire size was pretty much always 195/60-15 by the later models, and on the OG9-3. I don't know where they're getting 195/50 from......NG900 and possibly earlier OG9-3 used 205/50-16 tires, but I have not heard of 50-series 15" used. Maybe in Europe????
195/50 on 15" were quite popular in Germany in the 90s and 2000s before the trend to monster truck wheels even on sub-subcompacts had set in...I don't know where they're getting 195/50 from......NG900 and possibly earlier OG9-3 used 205/50-16 tires, but I have not heard of 50-series 15" used. Maybe in Europe????
