Looking for help removing the gear turret from a 2008 2.0 T,
What size are the 3 torx nuts that secure it to the tranny?
What else has to be removed to get the turret out?
How does one remove the 3 torx bolts that secure the battery box to the tranny?
I did this the other weekend all in only took 2h iirc the ones in the battery tray were T35 and the ones on the box were E45 I think, but I'll double check later.
The turret it self comes out fairly easy just need to maneuver if around the pipes or remove them I was able to just maneuver around them.
The rest of the removal of the turret repair you can find on YouTube
Sent from my ONEPLUS A5010 using Tapatalk
Thank you for the response.
Do the torx screws that hold the battery box to the chassis just unscrew without getting a wrench on the bolt on the underside of it? Did you use an impact driver to get them out?
