Hi
I had to put the crank at top dead centre to remove the valve cover - when refitting the manual says to ensure the distributor toggle engages with the cam end - how do I make sure I put the valve cover back on correctly so the distributor is correct ? I’m worried about screwing up the timing ? Thanks
That’s what I assumed ! So I guess the cover can only go back on if the cam end engages with the distributor toggle correctly anyway
