I`ve just discovered that I have a worn wheel bearing at the back of my car; while I was checking over all the rear suspension components I noticed something...
In the middle of the rear springs is a long plasic tube; which has become detached at one side of the car and is sitting loose.
It seems to have a threaded bolt at one end which I would have though would screw into the car body; however it does not want to.
More interestingly there is a air line going into this device - what is it for?!? :eek:
Any ideas welcome!
Ben.
Banned
Some.. Saabs came with Air Bag Spring Helper/load levelers .. (extra cost option I believe).. you have found the remains of that system. Should be a Big black rubber cylinder fitting inside the rear spring.. almost completely filling the space.. That's the Air Spring Gizmo.. had it still been there you would have noticed it :)
Hi guys, thanks for the quick replys!
Basre: The system is still there - the cylinder inside one of the back springs has come away from the car body.
Thanks all.
Ben.
