I was given this spoiler... I cant seem to find the template to drill the mounting holes. I currently have a make shift template made from cardboard. I dont know that I like that idea. Does anyone happen to have the templates that you can scan for me? If not, thats fine... I'll hope for the best with my cardboard.
If you find some threaded rod or screws the same size as the OEM screws, you would be able to cut 4 pieces of rod or the heads off the screws and grind a point on one end of each. thread those into the hole so just enough sticks out to dimple the cardboard and, while still pressing, trace around both bases onto the cardboard. Then just cut out the cardboard and you have a very accurate template. This way is pretty accurate for what you are looking to do.
Another way is use paint drop to screw heads and press spoiler to its place.
