1 - 7 of 7 Posts
· Registered
Discussion Starter · #2 ·
Anyone? Somebody out there has to have a schematic along these lines.
I installed my front seats last night. It was really quite easy on my '01 9-3 to upgrade to '99 9-3 motorized seats. I only had to run 2 wires from the fusebox, one blue/red red to each seat, and ground the relay ground wire on the passenger seat connector. I just tied it to the power ground on the connector itself.
On the fusebox I pulled a junker from the local pick-n-pull and used two nails to remove the fuse connector so it's a clean install using the intended fuse locations for each seat.
I need the rear seat heater wiring so I can connect the center console switch correctly.
1 - 7 of 7 Posts
