I have a p0411, and I'm fixing the SAI valve on the front of the engine. I was wondering, why does nobody ever talk about the rear sai valve?
Does it not go bad?
Sorry if this is a stupid question, but if they are both part of the same system, can the rear one also contribute to my p0411?
Both valves fail equally , but most common is the hose failing actually.
Cant remember seeing a post that u asked us to diagnose P0411 !
Done some reading on my own around the forums. If I'm wrong I've only done a few things that needed doing anyway. I needed to replace the turbo, which is most of the work.
I did the pump a little while ago, but now I'm doing the valve. I'll check the hoses too, thanks. Aside from pictures and degradation, is there something I should look for?
