Noticing slight top rear wheel tilt in on my 08.
I’m at 23.5” from bottom wheel lip to bottom fender lip. 24.15”/610mm is the spot on number I need for my 05 at least. Solved that w/1.0” spring spacers from the Saab guy on eBay.
Just want to be sure numbers are same after 05 (assuming so) and I’ll probably go with 1.0” ones this time as well. This is drivers side which was the same case as my 05. Driver side tends to lean in first it seems on these. Thanks
