1 - 8 of 8 Posts
· Registered
Hi all,
Sounds like panel rattle, had rear bumper off, checked/reformed heat shields, all interior rear interior trim panels,parcel shelf removed.........looked for anything obvious with all these off. Still there. Mrs sat in the back with interior panels off said it sounded like in the wheel arch.
Had inner wheel well cover off---nothing. Checked wiring all secure.......I'm out of ideas.
Suggestions anyone?
Thanks.
· Registered
c900 vert, 04 9-5 5pd wagon, 10 9-5 aero, 11 9-5 XWDsold
Anything under the rear seat, under the rug. Loose change?
· Registered
Rear drop links /end links on sway bar cause it?
It’s always there -worse on bumpy roads..but even backing down the driveway -rattle….
I’ve had a look under there all looks tight -but those rear ones are little stubby things—is removal the only way to tell if they’re stuffed—like front ones -if easy to move up & down etc worn out.
I’ve noticed a ‘ball joint’ on the cross stay —do these fail & become noisey ??
1 - 8 of 8 Posts
