1 - 2 of 2 Posts
Hi All
The rear hatch on my '87 9000 turbo will not unlock. The key will not turn the external lock and the central locking has given up opening it automatically.
Is there a way of unlocking the rear door, say by removing the trim off the door with the hatch closed - or is there an easy way?
Thanks
Neil
hatch
Sounds like the linkage between the lock and the mechanism came loose/disconnected. Take the trim cover off and reach around inside... feel for a vertical rod and work it up and down... should open the latch... good luck!
1 - 2 of 2 Posts
