My rear fog doesnt work and it doesnt appear to exist on the wiring diagram!
Can anybody tell me where it is fed from? Ive got no power at the back of the switch which is probably the reason it doesnt do owt.
I need to fix it for my MOT.
should it be fed through the fuse that is clipped above the headlight relay that is fed from the dipped beam output of the headlight relay?
Mine was all melted so it would explain its lack of working if it was from there!
were rear fogs optional for different countries or something? hence why they didnt get a real fuse?
it is indeed fed through that fuse. Easiest wiring fix ive done on the car so far! just had to clean the ends of the fuse and wiggle it a bit :)
Now works when dipped beam is on and the light in the switch works too :)
i seems to accidentally fix my wiper squirter at the same time which was clever! it was next on my list of jobs to inspect but i found it worked when i tried it after getting the fog going :)
