1 - 2 of 2 Posts
I have a 1988 900s and the right rear brake caliper is leaking around the spring where the emerengcy brake cable hooks up to... it leaks when the brake is put up and down..... seams like a bad seal..
I was woundering if there is a fix it yourself kit or does the entire caliper need to be replaced?
Thanks
Zach
Moderator
There is a kit though it's not the easiest caliper to rebuild. There's a circlip down in the centre of the caliper that holds the e-brake bit in that is a bit hard to get to...
1 - 2 of 2 Posts
