same
Inspect the boots carefully for any cracks, even surface cracks.
For some reason the LS inner boot is hard to find and extremely expensive at the dealer ($42); the others are normally priced and available..
I use cable ties rather than the strap(admittedly better); the plastic cable ties work and last - I think it is a matter of workmanship as much as anything.
The transmission side seals should be renewed. But I did not do this with any of my cars , not problem as yet- years later...
Re-lubricate the inners using CV grease, be generous, but not too; keep the area as clean as possible, dirt/grit is a no-no - this is easy to say, more difficult to do.
Use copious quantities of newspaper.
