Ive begun the project of turning my 1990 NA 900 into a rally/rallyX car.I always thought it was best to start with something slow to learn car control with.Today was its first day as a dedicated rally car.So I rally some roads just to get a better feel for the car and to start practising trail braking.10 minutes in,I accidentally hit a large rock,it just put a slight dent in the rim(was still holding air) so I went back to the shop to fix it(arn't steel wheels great!)I pulled into the shop only to find that the rock had bounced up and nicked the exposed drain plug.When it did that it also cracked the threads.No wonder it was leaking on the shop floor.Now I have to bring the car back into lewiston(an hour both ways) and have someone TIG the plug hole up so I can drill/tap the hole for the plug.Now I know what it needs to begin with-a 1" steel box frame for a 1/4" plate of aluminum to mount to.from the bumper all the way to the end of of the diff.Then a 1/4" aluminum skidplate for the gas tank then I should be golden,then box the A arms...I will try to get at least some pics of it next time I am up there.
I think this car will just be a training car so I will probally weld the diff rather than get a LSD..its rollcage wont be pretty but it will work
then a fast rally c900 or 99 with turbo and limited slip diff,with a DOM roll cage.
