woywitka said:
my old 84v had the original leak free radiator(21 years), my current saab has the original radiator (works pritty well):cheesy:
A 21 year old radiator will be knackered, whether it's actually leaking or not. They clog up with limescale, and no amount of flushing will clear that.
As I said before, there's just no point risking the survival or your car's engine on a relatively inexpensive and easily available part. You'll not be so smug when the engine boils over, blows the headgasket and seizes solid :lol:
As for radiator replacement, I've never done it on a 900, but I certainly will when I get another car. I replaced the radiator on a Volkwagen Passat, and that took six hours. The 900 looks loads easier, as there's less to remove in order to get the rad out. If you have the Bentley manual to hand, I'd say radiator replacement on a 900 is a job that anyone who's good with tools could do.
It's worth mentioning that tap water can contain large amounts of calcium and limescale. That clogs up the radiator, and is a major contributory factor in headgasket failure. Distilled water is cheap (less than £2.50/5 litres) and does not cause limescale buildup.
As for antifreeze, I use Comma X-Stream Green as it's based on the same formulation as genuine Saab and the now legendary Mercedes stuff.
