So here's a 2002 9-3 automatic, it's pretty crowded in here unless you remove a million things from the front.
https://imgur.com/a/6MjEDL5
WIS step #29 can be ignored, the condenser can be (carefully) disconnected from the housing without being unhooked from the two connecting pipes and tilted a little ways to the right.
-The airbox and air inlet pipe to the turbo have been removed.
-The serpentine belt has been removed and the power steering pump and fluid reservoir have been unscrewed from their respective housing.
-Both of the metal housings holding the air inlet pipe and power steering pump in place are removed.
-The coolant pump has been disconnected and removed. the power steering pump now partially occupies the space previously occupied by the airbox and coolant pump, serpentine belt.
When removing and installing the radiator, start a bit to the left to unhook the boot from the right-side condenser pipe. Remember, patience is a virtue
To reassemble follow WIS for both the coolant pump and radiator, starting with radiator steps 1-7, then pump, then the rest of the applicable radiator steps.
Take photos. bag, mark and label everything. I ended up not reinstalling most of the (7 total) air shields nor did I reinstall the headlight wipers and it will become one hell of a puzzle if you are not organized. Really none of those things rubber/plastic pieces matter except for impacting the resale value (dirt, slightly better than dirt) of the car.
