Hi passenger rad fan not coming on ever driver comes on fine both speeds how can I test ? 12 v to the fan clip? I tried looking for fuses and relays but only found a relay that apparently is behind or under the main fan clip that controls both (or 2 relays in that main fans clip)
do you know where a fuse is for the cooling fans? 2003 9-3 arc convertible
Maxi fuses 35 & 36 in engine bay UEC. Test by unplugging fan relay and jumpering 12V to fan motor.
2003 convertible is OG 9-3, others are NG.
