To check for shaft play on my turbo, can I simply remove the intercooler hose and check there, or do I have to remove the downpipe?
Also, anyone know if a TD04 19t would fit in my car? I know it's not a 'direct' fit per se because of some weird stuff with the lines, but is there a difference between the TD-04 15t and TD-04 19t?
You need to remove either the exhaust outlet or the air inlet pipe - there's no access from the exhaust inlet or air outlet. That is, you need to go in horizontally, not vertically.
